Dynatrace Managed Q&A
Running Dynatrace Managed in Kubernetes
tarjei
Organizer
Hi!
As a part of the installation of Dynatrace Managed I can see some flags.
K3S_KUBECONFIG_MODE and I also see: K3S_DO_INSTALL and K3S_ENABLED flags.
Does this indicate that it is possible or an option to run Dynatrace Managed as k3s?
Radoslaw_Szulgo
Inactive
Hi @tarjei , it's always a pleasure to answer your tricky and sophisticated questions.
What you've found is a leftover of a K3S configuration we have worked on in the past. We've dropped this development a long time ago and we won't resume it. The configuration should disappear completely in near future releases.
And to highlight clearly - you can't run Dynatrace Managed on any Kubernetes platform. It's not supported.
Senior Product Manager,
Dynatrace Managed expert
