Monitor LDAP Connection Pool - Dynatrace Managed
abed_nego270895
Newcomer
Can Dynatrace Managed monitor LDAP Connection Pool on the application server, that has the agent installed?
Julius_Loman
Depending on your monitored application deployed in your application server you will have to collect the metrics about your connection pool status. This is specific to the technology and framework used by your application. So the answer is yes, but not out of box.
