Extension 2.0: Load an updated extension
vpasinelli
Observer
to compensate for the lack of a fundamental metric for us and the customer. I downloaded the Apache Kafka extension (already present on the hub). I added the metric, changed the name, but now I can’t load the extension on our environment. Any suggestions on how?
7 REPLIES 7
Mike_L
Dynatrace Guru
Dynatrace Guru
Make sure that you rename the extension to custom, that you're signing it and uploading that cert to the credential vault. You can have a look at this video for more details: https://www.youtube.com/watch?v=KaLQhLmjP1o
Mike
AntonioSousa
If you are deploying your extensions (modifying existing extensions equally qualifies) you have to deploy them signed:
https://docs.dynatrace.com/docs/extend-dynatrace/extensions20/sign-extension
Antonio Sousa
Hi @AntonioSousa ,
I am trying to modify SQL Server Extension 2.3.0 using Visual Studio Code but I found a notification of "Cannot initialize workspace without certificates":
Do you know how to fix the problem? I believe the certificate is successfully uploaded to the Dynatrace credential vault and what next?
Hi @AntonioSousa ,
I have successfully initialized workspace yesterday.
I have renamed the sql server extension to custom but I got error code of 415 when I built the custom extension:
I have used the latest schema (1.291.0) because someone said the error will be fixed in schema 1.289.0:
https://community.dynatrace.com/t5/Dynatrace-API/Cloudevents-ingestion/m-p/236483
Any suggestions on how to upload the updated sql server extension?
Best Regards,
Rudy
