PostgreSQL Extension Problems
fcalega
Visitor
Hi Guys...
I am trying to configure the PostgreSQL extension. But I am having some problems.
The configuration data is correct.
I have tested the connection (telnet) from the Host where I have OneAgent installed to the database service/port, and it worked correctly.
Do you have any idea what is going on here?
Could you tell me how I can troubleshoot this connection?
Thank you very much.
Mike_L
Dynatrace Leader
Dynatrace Leader
Please create a support ticket so we can investigate the logs and the environment.
Mike
fcalega
Visitor
Hi @Mike_L , thanks for your answer.
I have had a support ticket since 12/08/22 but the support only sent me this extract of Log.
ConnectionRefusedError: [Errno 111] Connection refused
pg8000.core.InterfaceError: ('communication error', ConnectionRefusedError(111, 'Connection refused'))
The connection from Worker Node to database is working fine.
How we can do a database connection troubleshotting from oneagent?
thanks.
