Extensions
dt-sdk build command is building my custom extension with success but the signature is not valid
AurelienGravier
DynaMight Champion
DynaMight Champion
I encountered some troubles to move a custom python extension V2 from a sandbox tenant to a production tenant (the previous dev env doesn't exist anymore).
Actions done :
1- I created a new vscode project and I created a new python extension from an existing extension on sandbox tenant :
2- I edited the setup.py and I add required dependencies :
By comparison with the dependencies included on the extension.zip (on sandbox version) :
3-
When I build the extension through the UI, the following error appears related to the dependancy pycryptodomex :
When I use the command line dt-sdk build the extension is build with success :
Building and signing extension from . to None
Stage 1 - Download and build dependencies
Cleaning extension\lib
Downloading dependencies to extension\lib
Running: C:\Users\Aurélien\AppData\Local\Programs\Python\Python310\python.exe -m pip wheel -w extension/lib .
Processing c:\users\aurélien\documents\github\CLIENT\dynatrace-extension-cisco-wlc-v2
Preparing metadata (setup.py) ... done
Collecting dt-extensions-sdk (from ciscocontrollerwifi==0.0.25)
Using cached dt_extensions_sdk-1.2.14-py3-none-any.whl.metadata (2.7 kB)
Collecting requests>=2.6.0 (from ciscocontrollerwifi==0.0.25)
Using cached requests-2.32.3-py3-none-any.whl.metadata (4.6 kB)
Collecting pysnmp==4.4.12 (from ciscocontrollerwifi==0.0.25)
Using cached pysnmp-4.4.12-py2.py3-none-any.whl.metadata (1.8 kB)
Collecting snmp (from ciscocontrollerwifi==0.0.25)
Using cached snmp-0.8.0-py3-none-any.whl
Collecting pyasn1>=0.4.8 (from ciscocontrollerwifi==0.0.25)
Using cached pyasn1-0.6.1-py3-none-any.whl.metadata (8.4 kB)
Collecting pycryptodomex==3.20.0 (from ciscocontrollerwifi==0.0.25)
Using cached pycryptodomex-3.20.0-cp35-abi3-win_amd64.whl.metadata (3.4 kB)
Collecting pysmi (from pysnmp==4.4.12->ciscocontrollerwifi==0.0.25)
Using cached pysmi-1.5.5-py3-none-any.whl.metadata (3.2 kB)
Collecting charset-normalizer<4,>=2 (from requests>=2.6.0->ciscocontrollerwifi==0.0.25)
Using cached charset_normalizer-3.4.0-cp310-cp310-win_amd64.whl.metadata (34 kB)
Collecting idna<4,>=2.5 (from requests>=2.6.0->ciscocontrollerwifi==0.0.25)
Using cached idna-3.10-py3-none-any.whl.metadata (10 kB)
Collecting urllib3<3,>=1.21.1 (from requests>=2.6.0->ciscocontrollerwifi==0.0.25)
Using cached urllib3-2.2.3-py3-none-any.whl.metadata (6.5 kB)
Collecting certifi>=2017.4.17 (from requests>=2.6.0->ciscocontrollerwifi==0.0.25)
Using cached certifi-2024.8.30-py3-none-any.whl.metadata (2.2 kB)
Collecting pycryptodome>=3.4 (from snmp->ciscocontrollerwifi==0.0.25)
Using cached pycryptodome-3.21.0-cp36-abi3-win_amd64.whl.metadata (3.4 kB)
Collecting Jinja2<4.0.0,>=3.1.3 (from pysmi->pysnmp==4.4.12->ciscocontrollerwifi==0.0.25)
Using cached jinja2-3.1.4-py3-none-any.whl.metadata (2.6 kB)
Collecting ply<4.0,>=3.11 (from pysmi->pysnmp==4.4.12->ciscocontrollerwifi==0.0.25)
Using cached ply-3.11-py2.py3-none-any.whl.metadata (844 bytes)
Collecting MarkupSafe>=2.0 (from Jinja2<4.0.0,>=3.1.3->pysmi->pysnmp==4.4.12->ciscocontrollerwifi==0.0.25)
Using cached MarkupSafe-3.0.2-cp310-cp310-win_amd64.whl.metadata (4.1 kB)
Using cached pycryptodomex-3.20.0-cp35-abi3-win_amd64.whl (1.8 MB)
Using cached pysnmp-4.4.12-py2.py3-none-any.whl (296 kB)
Using cached pyasn1-0.6.1-py3-none-any.whl (83 kB)
Using cached requests-2.32.3-py3-none-any.whl (64 kB)
Using cached dt_extensions_sdk-1.2.14-py3-none-any.whl (47 kB)
Using cached certifi-2024.8.30-py3-none-any.whl (167 kB)
Using cached charset_normalizer-3.4.0-cp310-cp310-win_amd64.whl (102 kB)
Using cached idna-3.10-py3-none-any.whl (70 kB)
Using cached pycryptodome-3.21.0-cp36-abi3-win_amd64.whl (1.8 MB)
Using cached urllib3-2.2.3-py3-none-any.whl (126 kB)
Using cached pysmi-1.5.5-py3-none-any.whl (84 kB)
Using cached jinja2-3.1.4-py3-none-any.whl (133 kB)
Using cached ply-3.11-py2.py3-none-any.whl (49 kB)
Using cached MarkupSafe-3.0.2-cp310-cp310-win_amd64.whl (15 kB)
Saved c:\users\aurélien\documents\github\CLIENT\dynatrace-extension-cisco-wlc-v2\extension\lib\pycryptodomex-3.20.0-cp35-abi3-win_amd64.whl
Saved c:\users\aurélien\documents\github\CLIENT\dynatrace-extension-cisco-wlc-v2\extension\lib\pysnmp-4.4.12-py2.py3-none-any.whl
Saved c:\users\aurélien\documents\github\CLIENT\dynatrace-extension-cisco-wlc-v2\extension\lib\pyasn1-0.6.1-py3-none-any.whl
Saved c:\users\aurélien\documents\github\CLIENT\dynatrace-extension-cisco-wlc-v2\extension\lib\requests-2.32.3-py3-none-any.whl
Saved c:\users\aurélien\documents\github\CLIENT\dynatrace-extension-cisco-wlc-v2\extension\lib\dt_extensions_sdk-1.2.14-py3-none-any.whl
Saved c:\users\aurélien\documents\github\CLIENT\dynatrace-extension-cisco-wlc-v2\extension\lib\snmp-0.8.0-py3-none-any.whl
Saved c:\users\aurélien\documents\github\CLIENT\dynatrace-extension-cisco-wlc-v2\extension\lib\certifi-2024.8.30-py3-none-any.whl
Saved c:\users\aurélien\documents\github\CLIENT\dynatrace-extension-cisco-wlc-v2\extension\lib\charset_normalizer-3.4.0-cp310-cp310-win_amd64.whl
Saved c:\users\aurélien\documents\github\CLIENT\dynatrace-extension-cisco-wlc-v2\extension\lib\idna-3.10-py3-none-any.whl
Saved c:\users\aurélien\documents\github\CLIENT\dynatrace-extension-cisco-wlc-v2\extension\lib\pycryptodome-3.21.0-cp36-abi3-win_amd64.whl
Saved c:\users\aurélien\documents\github\CLIENT\dynatrace-extension-cisco-wlc-v2\extension\lib\urllib3-2.2.3-py3-none-any.whl
Saved c:\users\aurélien\documents\github\CLIENT\dynatrace-extension-cisco-wlc-v2\extension\lib\pysmi-1.5.5-py3-none-any.whl
Saved c:\users\aurélien\documents\github\CLIENT\dynatrace-extension-cisco-wlc-v2\extension\lib\jinja2-3.1.4-py3-none-any.whl
Saved c:\users\aurélien\documents\github\CLIENT\dynatrace-extension-cisco-wlc-v2\extension\lib\ply-3.11-py2.py3-none-any.whl
Saved c:\users\aurélien\documents\github\CLIENT\dynatrace-extension-cisco-wlc-v2\extension\lib\markupsafe-3.0.2-cp310-cp310-win_amd64.whl
Building wheels for collected packages: ciscocontrollerwifi
Building wheel for ciscocontrollerwifi (setup.py) ... done
Created wheel for ciscocontrollerwifi: filename=ciscocontrollerwifi-0.0.25-py3-none-any.whl size=6673 sha256=3bce758b15fbef94389812434a199d18917998b4edd78e909374d5299ebc66ff
Stored in directory: c:\users\aurélien\appdata\local\pip\cache\wheels\df\88\e0\715727277aabd7de4b4bdb20102ea463a5fc1e4bad67622d5e
Successfully built ciscocontrollerwifi
Installed dependencies to extension\lib
Stage 2 - Create the extension zip file
Running: dt ext assemble --source extension --output dist\extension.zip --force
Building dist\extension.zip from extension
Adding file: extension\activationSchema.json as activationSchema.json
Adding file: extension\extension.yaml as extension.yaml
Adding file: extension\lib\certifi-2024.8.30-py3-none-any.whl as lib\certifi-2024.8.30-py3-none-any.whl
Adding file: extension\lib\charset_normalizer-3.4.0-cp310-cp310-win_amd64.whl as lib\charset_normalizer-3.4.0-cp310-cp310-win_amd64.whl
Adding file: extension\lib\ciscocontrollerwifi-0.0.25-py3-none-any.whl as lib\ciscocontrollerwifi-0.0.25-py3-none-any.whl
Adding file: extension\lib\dt_extensions_sdk-1.2.14-py3-none-any.whl as lib\dt_extensions_sdk-1.2.14-py3-none-any.whl
Adding file: extension\lib\idna-3.10-py3-none-any.whl as lib\idna-3.10-py3-none-any.whl
Adding file: extension\lib\jinja2-3.1.4-py3-none-any.whl as lib\jinja2-3.1.4-py3-none-any.whl
Adding file: extension\lib\MarkupSafe-3.0.2-cp310-cp310-win_amd64.whl as lib\MarkupSafe-3.0.2-cp310-cp310-win_amd64.whl
Adding file: extension\lib\ply-3.11-py2.py3-none-any.whl as lib\ply-3.11-py2.py3-none-any.whl
Adding file: extension\lib\pyasn1-0.6.1-py3-none-any.whl as lib\pyasn1-0.6.1-py3-none-any.whl
Adding file: extension\lib\pycryptodome-3.21.0-cp36-abi3-win_amd64.whl as lib\pycryptodome-3.21.0-cp36-abi3-win_amd64.whl
Adding file: extension\lib\pycryptodomex-3.20.0-cp35-abi3-win_amd64.whl as lib\pycryptodomex-3.20.0-cp35-abi3-win_amd64.whl
Adding file: extension\lib\pysmi-1.5.5-py3-none-any.whl as lib\pysmi-1.5.5-py3-none-any.whl
Adding file: extension\lib\pysnmp-4.4.12-py2.py3-none-any.whl as lib\pysnmp-4.4.12-py2.py3-none-any.whl
Adding file: extension\lib\requests-2.32.3-py3-none-any.whl as lib\requests-2.32.3-py3-none-any.whl
Adding file: extension\lib\snmp-0.8.0-py3-none-any.whl as lib\snmp-0.8.0-py3-none-any.whl
Adding file: extension\lib\urllib3-2.2.3-py3-none-any.whl as lib\urllib3-2.2.3-py3-none-any.whl
Built the extension zip file to dist\extension.zip
Stage 3 - Sign the extension
Signing file dist\extension.zip to dist\custom_ciscocontrollerwifi-0.0.25.zip with certificate C:\Users\Aurélien\.dynatrace\certificates\developer.pem
Running: dt ext sign --src dist\extension.zip --output dist\custom_ciscocontrollerwifi-0.0.25.zip --key C:\Users\Aurélien\.dynatrace\certificates\developer.pem --force
Warning: skipping file permission check
Warning: overwritting dist\custom_ciscocontrollerwifi-0.0.25.zip
Created signed extension file dist\custom_ciscocontrollerwifi-0.0.25.zip
Stage 4 - Delete dist\extension.zip
But when I try to upload the extension file :
It's a really strange behaviour because the certificate path is correct to developer.pem.
Vscode env, sandbox AG and Prod AG use Windows systems.
Thank you.
Regards Aurélien.
Observability consultant - Dynatrace Associate/Pro/Services certified
4 REPLIES 4
AntonioSousa
@AurelienGravier,
Do you have the root CA in the Prod AG?
Antonio Sousa
Peter_Youssef
Leader
jonhaugen
Helper
When generating certificates from the SDK, it will generate a developer cert and a CA cert. (developer.pem/ca.pem)
By default you will find them under here:
c:\Users\{username}\AppData\Roaming\Code\User\workspaceStorage\{randomid}\DynatracePlatformExtensions.dynatrace-extensions\certificates\
Please try to upload the ca.pem to the credential vault first, before trying to upload the extension.
Note: you will find the complete path for the certificates from the setting pallet in visual code.
Intility - Dynatrace Professional
AurelienGravier
DynaMight Champion
DynaMight Champion
Hello guys,
Thank you for your help, the ca.pem was missing in the dynatrace vault prod environment 🙄.
