Extensions
dt-sdk module
Romanenkov_Al3x
DynaMight Champion
DynaMight Champion
Hello
I am trying to start to work with Add-on for VS Code
I want to try "Python extension 2.0"
The dt-sdk python module needs to be available on your machine for this setup to complete successfully.
Can anyone answer to me how I can get this module?
Alex Romanenkov
DT_NGINX_FORCE_UNKNOWN_VERSION_INSTRUMENTATION=1
13 REPLIES 13
Mike_L
Dynatrace Guru
Dynatrace Guru
Python in Extension Framework 2.0 is currently only available internally. We're planning to talk more about it for external use next quarter.
Mike
Thanks for fast answer. 👍
Any updates here?
We are planning to launch it around Perform. There is a HOT session there where you can get hands on experience.
Mike
Awesome news!  Thanks for information.
g_kat
Mentor
Based on the video released yesterday https://www.youtube.com/watch?v=Qy4Ge8HIzEk it looks like the framework for python data sources and development for Extensions 2.0 is available or about to be. Is there any scheduled announcement or documentation available?
George
"Jack of all trades and master of none, still better than master of one."
Dynatrace Extensions 2.0 provides a powerful framework to extend Dynatrace with additional observability domain knowledge for specific technology domains, e.g: Apache Kafka, F5 Load Balancers, Database Observability ... A Dynatrace Extensions allows every Dynatrace user to define what and how ...
Mike_L
Dynatrace Guru
Dynatrace Guru
It's scheduled for version 1.284 (February). We will release documentation in the January timeframe. It will be similar to this (currently in progress) documentation: https://dynatrace-extensions.github.io/dt-extensions-python-sdk/
Mike
Mike_L
Dynatrace Guru
Dynatrace Guru
GA of custom python extensions has been postponed to OA/AG 1.285, cluster 1.286
Mike
Hi Mike,
That's a bummer...
But, I noticed that in the documentation(https://docs.dynatrace.com/docs/extend-dynatrace/extensions20/data-sources/python) the python source is in Preview right now. Is there any other procedure beyond submitting the access form to get preview access?
George
Mike_L
Dynatrace Guru
Dynatrace Guru
There is no additional procedure required.
Mike
HI Mike - just to add to the discussion, for Dynatrace managed, does that mean we'll need to wait until our environment hits 1.285/1.286 before this feature set becomes available? (assuming yes?)
1.286 will be required both for Managed and SaaS.
Mike
Dang, suspected that was the case, but was hoping I was wrong 😊  Thanks as always Mike - much appreciated!
