1 of 1 Synthetic engine is offline - It was on running state
Can anyone tell me how to get it back please?
3 REPLIES 3
HannahM
Dynatrace Guru
Dynatrace Guru
Hi, it really depends on why it is offline. Please can you go to the Deployment Status page and check this ActiveGate there.
Perfect there, apart from Synthetic engine - offline
 This was due to chromium version update drawback. Ideally it should have auto upgraded with AG's update for my case it was not. Hence, it stopped responding. Ticket - 255061
