19 Sep 2024
07:02 PM
24 Sep 2024
12:30 PM
Michal_Gebacki
Can someone give me the api call to get the hosts associated with App ID, below is the output .. can someone get me the appropriate api call
"entityId": "HOST-xxx",
"displayName": "Ahghj.ally.corp",
"tags": [
"context": "CONTEXTLESS",
"key": "AppID",
"value": "104378"
19 Sep 2024 07:11 PM
Try this:
GitHub - dynatrace-oss/api-client-python: Dynatrace API Python client
from dynatrace import Dynatrace
from dynatrace import TOO_MANY_REQUESTS_WAIT
from dynatrace.environment_v2.tokens_api import SCOPE_METRICS_READ, SCOPE_METRICS_INGEST
from dynatrace.configuration_v1.credential_vault import PublicCertificateCredentials
from dynatrace.environment_v2.settings import SettingsObject, SettingsObjectCreate
from datetime import datetime, timedelta
# Create a Dynatrace client
dt = Dynatrace("environment_url", "api_token")
# Get all hosts and some properties
for entity in dt.entities.list('type("HOST"),tag("AppID:104378")'):
print(entity.entity_id, entity.display_name, entity.properties)
19 Sep 2024 07:16 PM
or this:
curl -X 'GET' \ 'https:/URL/e/ENV_ID/api/v2/entities?entitySelector=type%28%22HOST%22%29%2Ctag%28%22AppID%3A104378%22%29' \ -H 'accept: application/json; charset=utf-8' \ -H 'Authorization: Api-Token TOKEN'
19 Sep 2024 07:26 PM
thank you so much
25 Sep 2024 03:06 PM
Hi @huzoor
