When I tried running the workflow for auto fetch execution plan , the execution plan column is null for all sql id.
Same thing observed with our custom Database as well. However when we go and check manually the execution plan is there and asks to view on DB performance page.
Why I am getting this null execution plan for auto fetch dql ?
Regards
Amita
