Open Q&A
Davis Copilot not working in Explain with AI for problems
NicoleMT
Organizer
Hello, the Davis Copilot assistant is not working in Explain with AI for problems. The following message appears: "I'm sorry, but this doesn't seem to be a valid question. Please try rephrasing it or adding additional context."
6 REPLIES 6
NicoleMT
Organizer
chrmckenna
Participant
I am having the same issue.  Says the prompt that is generated by dynatrace is not a valid question
Kenny_Gillette
DynaMight Leader
DynaMight Leader
Seems sporadic.  I tried on different problems and worked on some then not others.  Tried on one problem and it worked then tried again, then it didn't work
deni
Mentor
This looks like a bug. I was able to reproduce the same behavior in the Dynatrace demo environment.
Dynatrace Integration Engineer at CodeAttest
Kenny_Gillette
DynaMight Leader
DynaMight Leader
I have opened a ticket for this:
https://one.dynatrace.com/hc/en-us/requests/534884
Kenny_Gillette
DynaMight Leader
DynaMight Leader
support found issue and fixed it.  I tested it so far and have not had any issues
