21 Aug 2025 05:22 PM
Hello, the Davis Copilot assistant is not working in Explain with AI for problems. The following message appears: "I'm sorry, but this doesn't seem to be a valid question. Please try rephrasing it or adding additional context."
28 Aug 2025 08:59 PM
I am having the same issue. Says the prompt that is generated by dynatrace is not a valid question
28 Aug 2025 09:15 PM - edited 28 Aug 2025 09:16 PM
Seems sporadic. I tried on different problems and worked on some then not others. Tried on one problem and it worked then tried again, then it didn't work
29 Aug 2025 06:53 PM
This looks like a bug. I was able to reproduce the same behavior in the Dynatrace demo environment.
29 Aug 2025 07:03 PM
I have opened a ticket for this:
https://one.dynatrace.com/hc/en-us/requests/534884
02 Sep 2025 01:43 PM
support found issue and fixed it. I tested it so far and have not had any issues
