Capture Response Body as Request Attribute (NGINX)
gary1024
Visitor
We have request on Nginx that always reply response 200 but need to look into response body to capture status of 'fail' or 'success'.
  "response": {
    "statusCode": 200,
    "body": "{\"message\":null,\"responseData\":{\"accountList\":[{\"accountNo\":\"2491011751\",\"canAddNewLine\":true,\"msisdnList\":[]}],\"deviceAdvancePaymentWaive\":\"N\",\"ratePlanAdvancePaymentWaive\":\"Y\",\"lineDepositWaive\":\"Y\",\"newProductOfferId\":\"4062147\",\"deviceDAPAmount\":\"540\",\"orderAck\":\"Y\"},\"status\":\"fail\",\"timeStamp\":\"2023-02-14 01:37:05\",\"violations\":null}"
However, looking at request attributes documentation does not really mention on this. Is there a way to capture this as an attribute?
Gary
Romanenkov_Al3x
DynaMight Mentor
DynaMight Mentor
Hello Gary.
We often set a request attribute for capturing arguments\return value from classes and methods which work with body \ make body response on App server level (on a Java backend for example) In this situation.
With custom error rules you can set to mark requests which have 200 response code and request attribute - error: value as failed.
Nginx in our situation is only balancer or web server to serve static files.
Romanenkov Alex
DT_NGINX_ALL_WHITELISTED=1
