IBM MQ Monitoring issue
kiranraju
Participant
We are observing that Dynatrace is adding dtdTraceTagInfo into messages sent by One of the applications to the downstream system which is causing messages to fail on the downstream side as they are not able to parse the message due to the presence of these additional named properties in MQ message.
We would like to know the are there any possibilities for disabling the "dtdTraceTagInfo" at the Queue or Host level in Dynatrace UI.
3 REPLIES 3
ChadTurner
DynaMight Legend
DynaMight Legend
@kiranraju were you able to get a work around to disable that dtdtaginfo in the messages? if not you might need a support ticket. Once you get the solution could you please share it with the community?
-Chad
JamesKitson
Dynatrace Guru
Dynatrace Guru
FYI this would be something done by the OneAgent not the IBM MQ extension. I'll move this to a more appropriate forum.
Babar_Qayyum
Hello @kiranraju
If I am not mistaken you are talking about the messaging service but not the extension. Am I correct? It is a custom message property so there should be a way to remove this but I am not sure what the consequences will be.
https://www.dynatrace.com/support/help/how-to-use-dynatrace/queues/queue-concepts
Babar
