Problem with Ansible integration in notifications
MariaElena
Contributor
Hi Team,
Your support in knowing why it gives an error in the connection when performing a test from Dynatrace to Ansible.
Does it have to do with a firewall?
Regards
3 REPLIES 3
DanielS
DynaMight Leader
DynaMight Leader
Simple observation, have in mind that only works with Ansible Tower. Not just Ansible.
The true delight is in the finding out rather than in the knowing.
Hi Daniel,
Yes, it is with Ansible Tower.
Regards
Hi @MariaElena, if you're using Tower. Yes, could be a Firewall, or communication problems, can you check first if the Ansible Tower services are working ok?
