Recommendation for ActiveGates for Production Dynatrace SaaS environment
gargigharat
Newcomer
Hi Team,
We are using Dynatrace SaaS environment for our POC purpose and want to have the same for Production environment too. Kindly recommend the type for Active Gates to be used for Production setup(Host-based Active Gate or Containerized Active Gate).
And also suggest the limitations of these two types of Active Gates.
Gargi Gharat
3 REPLIES 3
Mike_L
Dynatrace Guru
Dynatrace Guru
As you posted this in the extensions forum I'll answer from an extensions point of view. Containerized ActiveGates are currently not able to run extensions.
Radoslaw_Szulgo
Dynatrace Guru
Dynatrace Guru
I think this doc page may help you:
https://www.dynatrace.com/support/help/shortlink/ag-container-differences#purposes
Senior Product Manager,
Dynatrace Managed expert
There is a config recommendation from Dynatrace (2022)
Proxy:
Minimum: 2 vCores, 4GB RAM, 20 GB disk
Ideal: 4 vCores, 8GB RAM, 20GB disk
for Synthetics
8 vCores, 32GB RAM, 50GB disk
In AWS closest config:
- 4 vCores, 16GB RAM, 20GB disk
- 8 vCores, 32GB RAM, 50GB disk
