Open Q&A
Workarounds for placing Key Requests in Maintenance Mode?
Kenny_Gillette
DynaMight Leader
DynaMight Leader
Hi team,
Has anyone successfully placed a specific Key Request into maintenance mode? I’m currently unable to do this directly.
I am aware that I can adjust thresholds or mute the specific request, but I am looking for a true maintenance mode solution if one exists.
Does anyone have a workaround for this?
4 REPLIES 4
AntonPineiro
I would say mute request.
Or as it is key request, swith off failure rate and anomaly detection settings only for that key request.
Best regards
ChadTurner
DynaMight Legend
DynaMight Legend
you can prolly expand what @AntonPineiro outlined and make a workflow to execute the "turn back on" action.
Great question!
-Chad
Kenny_Gillette
DynaMight Leader
DynaMight Leader
Thanks to you both.
Next question - maybe I should put in a separate post:
How about otel and end points.  No option for muting or key requests.
good point, Otel - is that data feeding into a custom entity? - if so, you should be able to target that
-Chad
