16 Dec 2025
04:05 PM
18 Dec 2025
07:34 AM
Hi team,
Has anyone successfully placed a specific Key Request into maintenance mode? I’m currently unable to do this directly.
I am aware that I can adjust thresholds or mute the specific request, but I am looking for a true maintenance mode solution if one exists.
Does anyone have a workaround for this?
16 Dec 2025 04:14 PM - edited 16 Dec 2025 04:17 PM
I would say mute request.
Or as it is key request, swith off failure rate and anomaly detection settings only for that key request.
Best regards
17 Dec 2025 01:12 PM
Exactly what I was thinking but wanted to confirm with others.
16 Dec 2025 09:16 PM
you can prolly expand what @AntonPineiro outlined and make a workflow to execute the "turn back on" action.
Great question!
16 Dec 2025 09:22 PM
Thanks to you both.
Next question - maybe I should put in a separate post:
How about otel and end points. No option for muting or key requests.
16 Dec 2025 09:36 PM
good point, Otel - is that data feeding into a custom entity? - if so, you should be able to target that
17 Dec 2025 01:14 PM
yes, endpoint. part of span.
Let me make a separate post for this since it is different
17 Dec 2025 01:32 PM
