Produktideen (Product Ideas)
denis_holdeew
Observer
Status: New
In the data explorer, it's possible to select a row and then navigate via the button "View service list" to a multidimensional analysis. It would be a good user-experience if the multidimensional analysis would have filters pre-set that are based on the dimension values of the selected row in the data-explorer. Currently, the multidimensional analysis is not pre-filtered with the dimensions of the selected row in the data explorer.
The example below shows the behavior. In the data explorer the selected dimension is ProcessIdentifier. The first row from the top table is selected and a popup opens up displaying the dimension value of the selected row. Then a navigation happens via "View service list". Now it would be nice, if there would be a pre-set filter in the multidimensional analysis which corresponds to the value of the "ProcessIdentifier" dimension. In case of more dimensions, all of these should be pre-filtered in the multidimensional analysis:
1 Comment
AntonPineiro
As it is written in English, do you prefer I move to general thread about product ideas?
It will have more visibility.
Best regards
Suggest an idea
Share your feedback:
