07 Aug 2019
07:37 AM
27 Apr 2021
12:49 PM
Dear All,
What are the best practices to monitor/configure the applications without real user monitoring is turning on?
The use case is that recently we instrumented an application and customer is not interested in RUM for this application.
We disabled the RUM "Dynatrace real user monitoring is turned off." and application status changed to "Unmonitored" and secondly the monitoring data is going into "My web application" even the domain mapped to the newly created application.
Babar
07 Aug 2019 08:07 AM
If real user monitoring is off, you should not get user actions - even not in the default application. Only service data should be available.
Is the application instrumented by auto injection or manual (agentless)?
I would suggest to create a support ticket, so we can take a look.
07 Aug 2019 08:35 AM
Hello @Alexander S.
We are not expecting any RUM data for the application as well as for the "My web application" even though user actions are appearing in the "My web application" for the application.
Application is auto instrumented.
Babar
07 Aug 2019 08:40 AM
07 Aug 2019 01:21 PM
Hello @sebastian k.
I guess this is something new for me. Can you please assist me a little more to this direction?
Babar
07 Aug 2019 01:31 PM
Go to process group => Edit and you can switch it of for all servers that are servinh HTML, and that's all. You are 100% sure that agent isn't injected anywhere.
07 Aug 2019 02:23 PM
Hello @sebastian k.
I turned off the JavaScript tag on the process level and will provide you the feedback of this change.
Babar
