Start with Dynatrace
Problem Notifications - Ansible
Peter_Youssef
Leader
The following configuration procedures describe the integration configurations between Dynatrace and Ansible for problem notifications.
Prerequisites:
  • Communications should be allowed either between Dynatrace cluster nodes or ActiveGates and Ansible Tower instance.
  • Obtain the ansible tower URL from Ansible Tower instance, copy the URL shown in the template UI.
As per the attached ansible tower configuration template screenshot:
  • The mandatory variables are marked with *.
  • The remaining parameters are optional.
  • As per requirements, you can add more variables through Yaml or Json files.
On Dynatrace side
  • It's better to Have cluster admin privileges, but you can also configure it through having the following permissions "Change monitoring settings", "Download & install OneAgent", "Access environment".
  • Under Manage menu > Settings > Integration > Problem notifications > Ansible.
  • Specify the below parameters as per attached example.
  • It's mandatory to specify the Username and password provided by Ansible team.
  • The custom message which will be used as a placeholder is an optional variable, you can ignore if not required.
  • Select the alerting profile, if not selected the default will be used automatically.
  • Final step: Send test notification to ensure current configurations are accurate and notifications are delivered as intended.
:dynahistory::dynatrace_logo:📯📢
0 REPLIES 0
