16 Nov 2022 08:45 AM
Hi all,
I currently just started with my first synthetics but our plan is to integrate the on demand triggers in GitHub Actions and then read if it passed. I know Dynatrace has a GitHub actions integration but I can't find anything on if we can also access the synthetics.
In short:
I also know there is an API but I would rather use a pre-made solution.
Thanks in advance!
16 Nov 2022 08:53 AM
The Github Action for Dynatrace reports events or metrics, I don't think there is one for your use case.
But as you mentioned you can use a HTTP Request action to make an API call to the Environment v2 API (/synthetic/executions) to trigger the test and get the result.
