11 Apr 2022 01:28 PM
Could someone help how to customize the script to handle multiple users in the browser click path monitor.
11 Apr 2022 01:57 PM
Does this example help? It allows a user to be set per location that the monitor is running on.
What is your use case?
12 Apr 2022 11:32 AM
Hi @SE
Please refer below similar link with accepted solution.
Solved: Synthetic Monitoring with Multiple Users - Dynatrace Community
KG
