Synthetic Monitoring
Handle multiple users in synthetic monitoring
SE
Frequent Guest
Could someone help how to customize the script to handle multiple users in the browser click path monitor.
HannahM
Dynatrace Guru
Dynatrace Guru
Does this example help? It allows a user to be set per location that the monitor is running on.
What is your use case?
techean
Inactive
Hi @SE
Please refer below similar link with accepted solution.
Solved: Synthetic Monitoring with Multiple Users - Dynatrace Community
KG
KG
