01 May 2022 04:36 PM
I have deployed a second Activegate at a location. It has more processing power, a newer Chrome version, and was looking to see if I could see differences between both of them. But looking, I'm unable to find a way to differentiate measurements. I do know that both are doing measurements, as seen splitting by AG id with the metric dsfm:synthetic.browser.engine_utilization
Any idea how I could do this?
03 May 2022 10:23 AM
You can see the information for a single execution. If you click on the location link for an execution it will take you to the ActiveGates page filtered on that one ActiveGate.
But you're right, I can't think of any metrics, other than the utilization ones that provide this option.
03 May 2022 11:30 AM
Nice point! Even better, just looking at the URL tells us which one it is, so you don't have to click it. It's not the fastest way, but gets the job "slowly" done.
I'm going to create a Product Idea, as combining several AGs to make tests might be a way to enable testing (eg. different browsers, different server characteristics, etc.) with Dynatrace 😁
