Synthetic Monitoring
How to enable browser monitoring for the url with otp enabled login?
Arunkumarbnp
Helper
how to enable browser monitoring for the url with otp enabled login?
3 REPLIES 3
Peter_Youssef
Leader
Hi @Arunkumarbnp
It's a matter of creating browser clickpath and you will have to specify the below
  1. The next event will be the OTP verification which can't be monitored directly by Dynatrace but Dynatrace will trigger either the successful or failed OTP verifications.
  2. Also content validation rules will be helpful as well
Related Ref:
Hoping it helps,
BR.
Peter
Peter_Youssef
Leader
Hi @Arunkumarbnp
There is a similar case where you can just enable global login authentication, configure the available parameters as per the provided inputs:
In case you won't proceed with clickpath, follow the below example
Thanks.
