Synthetic Monitoring
How to setup browser monitoring for sso enabled application urls, we are using smart card enabled sso so authentication is auto
Arunkumarbnp
Helper
How to setup browser monitoring for sso enabled application urls, we are using smart card enabled sso so authentication is automated.
HannahM
Dynatrace Guru
Dynatrace Guru
Thanks for the question. I see you got some answers here. I'm not sure this type of SSO would be suitable for Synthetic monitoring, as it requires a physical card, so it's likely a work around would need to be provided, such as an API to get the token or some way to bypass it.
