Synthetic API gives availability by location, but not the aggregated value. I think the following image explains the idea:
It would be great to get this!
Hi Antonio, did you have a look at the metrics API? I think this should be possible with the merge transformation. See https://www.dynatrace.com/support/help/shortlink/api-metrics-v2-selector#merge-transformation for details.
Kind regards, Philipp
Yes, you are right!. Just changed my script and it's not splitting the value any more.
Now, this is not an RFE anymore. Can this be changed to a question?
Done 😉
@Antonio, Could you please share the sample script which worked for you to get the above details?
Also, am looking to get the synthetics= monitors availabaility based on months/weeks/year. Can you sahre sample curl request for the same?
The curl is the one I referenced in my post on 19 May 2020. To do what I was asking for, you have to add the merge transformation, as referenced in the link that Philipp_Kastner referenced.
@Antonio S. , Could you help me fetching synthetic monitor availability and response time using API method ? where shall I find the list of metric selector to fetch the above 2 metrics ?
I mainly use v2 of the API:
https://www.dynatrace.com/support/help/dynatrace-api/environment-api/metric-v2/
One example would be like the following, which is for yesterday's values (mind you have to put your environment as yyyyyy and your API as zzzzzzzzzzzzzzzzzzzzzzzzz):
curl -X GET "https://yyyyyy.live.dynatrace.com/api/v2/metrics/query?metricSelector=builtin%3Asynthetic.browser.availability.location.total&resolution=Inf&from=1589760000000&to=1589846400000" -H "accept: application/json; charset=utf-8" -H "Authorization: Api-Token zzzzzzzzzzzzzzzzzzzzzzzzz"
How to get the details of a particular synthetic , by executing the above query we are getting all the synthetic availability and also only the latest availaility
