Synthetic : Exclude some step from monitoring
We have some use cases where we need to do some steps into synthetic monitoring without impact the monitoring data.
For instance, for a retail website we can have different steps to add a product to basket, other steps to order and also a last step to cancel the order. It could be usefull to exclude this last step because it is just an technical step just to prevent stocks issue.
ChadTurner
Guru
You can block specific requests by selecting "Edit" on the monitor, Advanced Setup, then list the things you'd like to have blocked,
Let me know if you need an hand with this
-Chad
