11 Jul 2023
06:01 AM
11 Jul 2023
08:33 AM
Hello Champs,
Greetings !!
I'm having a tipical issue on synthetic HTTP monitoring via private location. My applications are hosted on k8s and Which are exposed external via load balancer to access through application service urls. as per the k8s structure.. if I use the service name url it will redirect to the right application service to vial load balancer and access it. Now, I'm trying to configure the sythetic monitoring for these services via service specific urls (FQDN)it is failing . I installed the active gateway on the vm and I can able to do the curl for this service url successfully. But when I configure via dynatrace synthetic monitoring it is failing with REQUEST TIMEOUT. any hints please ?
11 Jul 2023 08:12 AM
Hi @Balap
Have you verified the log entries on the ActiveGate and on the DT server side?
I suspect a problem with the proper configuration of network.
Radek
11 Jul 2023 01:35 PM
What do you see in 'Analyze last execution'? Is the FQDN being resolved as you expect?
Are you using /etc/hosts file? If so, the HTTP Monitor is unable to use it. Browser Monitors can, so that could be a solution if you need to.
Are you using any proxies?
12 Jul 2023 03:52 PM
Thanks Mates.
It is problem with the Proxy Internal . After I add those details. I am able to set it up.
https://www.dynatrace.com/support/help/shortlink/sgw-proxy-authentication#internal
Thanks for your support
