Synthetic Monitoring
Synthetic tests - Private and Cluster types
In the documentation it is mentioned:
Possible values for the type element in the LocationCollectionElement object:
  • CLUSTER
  • PRIVATE
  • PUBLIC
https://www.dynatrace.com/support/help/dynatrace-api/environment-api/synthetic/synthetic-locations/g...
How Cluster type is different than Private?
Also:
Possible values for the status element in the LocationCollectionElement object:
  • DISABLED
  • ENABLED
  • HIDDEN
What purpose Hidden has?
Thanks.
3 REPLIES 3
HannahM
Dynatrace Guru
Dynatrace Guru
Hi Irakli,
you're correct that 'CLUSTER' is indeed a type of private location but it is good to differentiate between them as a 'PRIVATE' location is only available to 1 environment whereas a 'CLUSTER' location is available to multiple environments within a managed cluster.
'HIDDEN' is used for locations that are available for some tenants but not others. So we mark them as 'HIDDEN' in the accounts that they are not available for. I don't believe that we have any of these at the moment though.
Best wishes, Hannah
Thanks, Hannah,
So if I want to create a private synthetic test location that is available for all environments in the cluster I should set it up as Cluster, and set up the corresponding Cluster ActiveGate, correct?
Yes, you need to follow the Cluster ActiveGate instructions here.
