Synthetic Monitoring
When dynatrace synthetic debugger is on CloudFront returns HTTP 502 bad gateway
Yosi_Neuman
Hi guys,
Customer tries to record a click path and the page return http 502 error from CloudFront as long the debugger is on
After canceling the debugger the page is loaded with no issue.
When executing / playback the recorded steps we get all the time http 502.
SO our questions are:
  1. Is there a way to switch off the debugger while executing the steps?!
  2. What is the debugger use for in recording and playback / execution of a test?
  3. Do we know what we need to ask the CloudFront guys to set in order to over come this error?
Thanks in advance for your help with that
Yos
4 REPLIES 4
AntonioSousa
@Yosi_Neuman,
I have had similar issues before, but they were related to the parameters added to the User-Agent HTTP Header by Dynatrace Synthetics. At the time, I confirmed this with curl requests, adding the modified User-Agent... If it's the case, you'll also get the 502's back.
Antonio Sousa
Yosi_Neuman
Hi @Peter_Youssef  & @AntonioSousa
Thanks for your inputs on this subject, my case was solved by a "magic" from security guys
Have no idea what was changed and also think security guys don't have a clue too :angel:
May be its was related to the synthetic user agent but not sure.
Yos
Thanks @Yosi_Neuman for the update.
We would appreciate providing us the key behind the resolution for future scenarios.
KR,
Peter.
