Troubleshooting
MonikaBalogh
Dynatrace Advisor
Dynatrace Advisor
If you add your issue-tracking system in Dynatrace but don't see any results in Tracked issues, select Configure, go to the details of your issue tracker, and check if the target URL and the credentials provided are correct. You can select Check configuration for an error message about the problem.
Version history
Last update:
‎06 Dec 2023 10:53 AM
Updated by:
Community freeze: read-only from October 22, 6:00 AM UTC, while we move to Discourse. Outage (~1h) on October 26 at 9:00 AM UTC. Learn more.
