Troubleshooting
maliborskaya
Dynatrace Advisor
Dynatrace Advisor
If you've encountered an issue related to Dynatrace OpenKit, for example, if no data is sent to your custom application, ensure the following.
  • You've confirmed that Dynatrace and your Cluster ActiveGate are reachable from your company network.
  • You've confirmed that the ActiveGate is configured with a valid SSL certificate.
  • If you've using a .NET Framework version lower than 4.7: Starting with April 2022, Dynatrace SaaS only supports TLS 1.2+. For this reason, using a .NET Framework version lower than 4.7 might require additional configuration.
Version history
Last update:
‎26 Dec 2023 01:50 PM
Updated by:
