on
21 Nov 2024
08:11 AM
- edited on
30 May 2025
08:16 AM
Below are the three common scenarios during the Dynarace One agent update. Let's check how it's fixable.
Scenario 1.
This happens in Windows machines.
This is not a Dynatrace issue; the error message points to the MS error code, which can happen for many reasons. For more details, please check the page below.
MSI installation error 1603 - Windows Server | Microsoft Learn
Scenario 2.
This happens in Linux hosts.
In the OS logs we can see the warning message for this
Error: Detected that /opt/dynatrace/oneagent is a dangling symlink, please remove it and then retry the installation
It means the installation directory is soft-linked, which is not supported. The installation path must be the real directory. This is why the Agent update keeps failing.
Scenario 3.
This is a self-explanatory issue; the updates can fail due to insufficient disk space.
Scenario 4.
This issue happens in Linux hosts; this can be due to many reasons.
Running the health check will show the details.
./oneagentctl --healthcheck
Hi, about scenario 3, how can we check in advance if a host has sufficient disk space?
My idea is to run a check 2 weeks before oneagents update to detect hosts on which to increase disk space when it is insufficient.
Hi Paolo,
The logic of checking if there are enough spaces is invoked during the update/installation step. As of now, it's not possible to check the disk space in advance.
But this page will be helpful.
https://docs.dynatrace.com/docs/shortlink/oneagent-disk-requirements-windows#updates
