How to check if Cassandra is corrupted on the Managed node?
ERROR [CompactionExecutor:544] 2019-02-19 13:26:55,920 CassandraDaemon.java:231 - Exception in thread Thread[CompactionExecutor:544,1,main] org.apache.cassandra.io.sstable.CorruptSSTableException: Corrupted: /metricsDisk/cassandra/ruxitdb/Ts2Final01Min-967699b0f56011e7ad0403861a5cb15c/ruxitdb-Ts2Final01Min-ka-356332-Data.db ERROR [CompactionExecutor:566] 2019-02-19 13:30:20,207 CassandraDaemon.java:231 - Exception in thread Thread[CompactionExecutor:566,1,main] org.apache.cassandra.io.sstable.CorruptSSTableException: Corrupted: /metricsDisk/cassandra/ruxitdb/Ts2Volatile01Min-960efe40f56011e7ad0403861a5cb15c/ruxitdb-Ts2Volatile01Min-ka-65282-Data.db ERROR [CompactionExecutor:564] 2019-02-19 14:05:25,489 CassandraDaemon.java:231 - Exception in thread Thread[CompactionExecutor:564,1,main] org.apache.cassandra.io.sstable.CorruptSSTableException: Corrupted: /metricsDisk/cassandra/ruxitdb/Ts2Final01Min-967699b0f56011e7ad0403861a5cb15c/ruxitdb-Ts2Final01Min-ka-345130-Data.db
/var/opt/dynatrace-managed/cassandra/ruxitdb/Me2Data-0763a420293b11e8946add4c85a31f71/ruxitdb-Me2Data-tmp-ka-202976-Data.db
In such cases, Cassandra must be repaired!
Note timezone in Cassandra logs is the local time of the host Cassandra is running at
I assume the log file is debug.log and not cassandra.log? I only see system.log, debug.log and launch.log in the default /opt/dynatrace-managed/cassandra/log/ directory 🙂
It looks like debug.log is the one that would contain the info you mentioned.
