bharat_pitta
Dynatrace Guide
Dynatrace Guide
Question
How to check if Cassandra is corrupted on the Managed node?
Answer
  • Open the Cassandra log file, usually located in :/opt/dynatrace-managed/cassandra/log/cassandra.log
  • Check if there are any corrupted messages in logs like those below
ERROR [CompactionExecutor:544] 2019-02-19 13:26:55,920 CassandraDaemon.java:231 - Exception in thread Thread[CompactionExecutor:544,1,main]
org.apache.cassandra.io.sstable.CorruptSSTableException: Corrupted: /metricsDisk/cassandra/ruxitdb/Ts2Final01Min-967699b0f56011e7ad0403861a5cb15c/ruxitdb-Ts2Final01Min-ka-356332-Data.db
ERROR [CompactionExecutor:566] 2019-02-19 13:30:20,207 CassandraDaemon.java:231 - Exception in thread Thread[CompactionExecutor:566,1,main]
org.apache.cassandra.io.sstable.CorruptSSTableException: Corrupted: /metricsDisk/cassandra/ruxitdb/Ts2Volatile01Min-960efe40f56011e7ad0403861a5cb15c/ruxitdb-Ts2Volatile01Min-ka-65282-Data.db
ERROR [CompactionExecutor:564] 2019-02-19 14:05:25,489 CassandraDaemon.java:231 - Exception in thread Thread[CompactionExecutor:564,1,main]
org.apache.cassandra.io.sstable.CorruptSSTableException: Corrupted: /metricsDisk/cassandra/ruxitdb/Ts2Final01Min-967699b0f56011e7ad0403861a5cb15c/ruxitdb-Ts2Final01Min-ka-345130-Data.db
  • Corrupted files where the filename contains Ts are not critical, since only time-series data is involved (like the sample from above).
  • Corrupted files where the filename contains Me are critical since configuration data is involved. An example of such file name would be following
/var/opt/dynatrace-managed/cassandra/ruxitdb/Me2Data-0763a420293b11e8946add4c85a31f71/ruxitdb-Me2Data-tmp-ka-202976-Data.db
In such cases, Cassandra must be repaired!
Note timezone in Cassandra logs is the local time of the host Cassandra is running at
Version history
Last update:
‎03 Jan 2023 02:43 AM
Updated by:
Comments
ChadTurner
DynaMight Legend
DynaMight Legend
Thank you @bharat_pitta for this troubleshooting tip/trick 🙂
andre_vdveen
DynaMight Champion
DynaMight Champion
Hi @bharat_pitta
I assume the log file is debug.log and not cassandra.log? I only see system.log, debug.log and launch.log in the default /opt/dynatrace-managed/cassandra/log/ directory 🙂
It looks like debug.log is the one that would contain the info you mentioned.
