 HannahM
			HannahM
		on 02 Jan 2024 10:00 AM
Sometimes a simple click is not sufficient and a right-click is needed. This can be achieved through a JavaScript Event.
| Issue | Solution | Tasks | Alternative(s) |
| Right-click is needed | Use a JavaScript event | Find the relevant locator Update the snippet | If this does not work, you can ask on chat to check your code. |
Steps to follow to perform a right-click in a Browser Clickpath Synthetic Monitor
Go to the relevant page in a Chrome browser
Right-click on the element which you want to interact with on the page and select Inspect. The element will then be shown in Developer Tools
Right click on the element on the Web developer tools - > Copy - > Copy JS path
Paste the JS path on the below element value
function rightClick(element){
  var evt = element.ownerDocument.createEvent('MouseEvents');
  var RIGHT_CLICK_BUTTON_CODE = 2; // the same for FF and IE
  evt.initMouseEvent('click', true, true,
      element.ownerDocument.defaultView, 1, 0, 0, 0, 0, false,
      false, false, false, RIGHT_CLICK_BUTTON_CODE, null);
  return !element.dispatchEvent(evt);
var element = document.querySelector('button[id="testid"]'); //Replace with the element which you want to right-click.
rightClick(element);
Add a new event into the monitor, where you need to right-click and paste in the updated snippet above.
Hello ,
I have tried to implement that but I am getting the below error once i have playback the record.
Playback error: Exception was thrown by the JavaScript code: Cannot read properties of null (reading 'ownerDocument')
Is there any recomendation to overcome this issue?
Thank you
