07 Jun 2023 04:24 PM - edited 27 Apr 2026 01:09 PM
Browser Clickpath Monitors support DOM and CSS locators out of the box. This covers most scenarios, but for some applications, an XPath locator is needed. This article will explain how to select one.
You can either use the XPath locator directly as a locator or use a JavaScript event for clicking.
document.evaluate('xpath', document, null, XPathResult.FIRST_ORDERED_NODE_TYPE, null).singleNodeValueReplacing xpath with the XPath captured previously
function getElementByXpath(path) {
return document.evaluate(path, document, null, XPathResult.FIRST_ORDERED_NODE_TYPE, null).singleNodeValue;
a1 = getElementByXpath('xpath');
a1.click();
If none of the previous steps resolved the issue, open a chat and provide a link to the monitor you're updating and the configuration steps you have already completed.
I know that the post is very old but Could you tell me how to implement a condition if the by chance the object (dropdown) has not been load on the page to throw an exception, please?
Could you add a javascript event and check if the resource loaded as expected?
performance.getEntriesByName("https://domain.com/fonts/bernina/BerninaSans-Web-Light.woff")[0].responseStatus
response would be 0 if it hasn't loaded.
Thanks a lot!
You not only solved my question but also gave me ideas for other questions.
Hi team,
It looks like the design of the ticketing page has changed slightly which is causing an alert in Dynatrace. We have a synthetic script is flagging an issue with not being able to click on "XXX" but in the new design just shows "YYY" in a circle instead. How Can we adjust the test script for this?
B.Mahathi
You'll need to update the script. If it's just the locator that has changed, you can find it using the steps above and then update the relevant event. If the flow of the pages has changed, it may be easier to re-record the script.
