moritzwitti
Dynatrace Participant
Summary
The Dynatrace OneAgent is incompatible with Java processes that have Ahead-of-Time (AOT) class loading enabled. This incompatibility may cause your application to crash or to disregard the AOT cache.
Problem
The Java 24 feature "Ahead-of-Time Class Loading & Linking" is inherently not designed to work with JVMTI agents, such as OneAgent. Therefore, OneAgent won't function with a Java process that has Ahead-of-Time class loading enabled; your application might crash or disregard the Ahead-of-Time cache. The error message to expect in this case is java.lang.ClassNotFoundException.
Resolution
To enable OneAgent monitoring for Java processes, remove parameters related to Ahead-of-Time Class loading.
Source
What's next
If this article did not help, please open a support ticket, mention that this article was used and provide the following in the ticket:
Version history
Last update:
‎07 Apr 2025 01:59 PM
Updated by:
