Troubleshooting
DietmarS
Dynatrace Contributor
If extra_vars are sent from the workflow action "Launch job template" and they are ignored on the Automation controller, check the following setting of your job template in the Automation Controller.
Make sure that the checkbox for “Prompt on launch” for variables (extra_vars) is checked on the job template in your controller.
Version history
Last update:
‎16 May 2024 07:38 AM
Updated by:
