xu_guo
Dynatrace Organizer
Dynatrace Organizer
Summary
This article provides the most common error codes seen in Dynatrace Synthetic browser monitors, along with note on the behavior and some troubleshooting suggestions.
For any HTTP Response code errors, follow the troubleshooting steps here.
For connection issues, check Firewall Constraints and allowlisting for Synthetic Monitoring
Error Codes
Error
Detail
Test fails
Error category
Notes
400
Bad Request
Yes
HTTP response code
All errors are reported in the same tab
401
Unauthorized
Yes
HTTP response code
gets reported in a same tab since APM-108556
402
Payment Required
Yes
HTTP response code
403
Forbidden
Yes
HTTP response code
404
Not Found
Yes
HTTP response code
405
Method Not Allowed
Yes
HTTP response code
406
Not Acceptable
Yes
HTTP response code
407
Proxy Authentication Required
Yes
HTTP response code
408
Request Timeout
Yes
HTTP response code
409
Conflict
Yes
HTTP response code
410
Gone
Yes
HTTP response code
411
Length Required
Yes
HTTP response code
412
Precondition Required
Yes
HTTP response code
413
Request Entry Too Large
Yes
HTTP response code
414
Request-URI Too Long
Yes
HTTP response code
415
Unsupported Media Type
Yes
HTTP response code
416
Requested Range Not Satisfiable
Yes
HTTP response code
417
Expectation Failed
Yes
HTTP response code
418
I am a Teapot
Yes
HTTP response code
419
Authentication Timeout
Yes
HTTP response code
420
Method failure
Yes
HTTP response code
421
Misdirected Request
Yes
HTTP response code
422
Unprocessable Entity
Yes
HTTP response code
423
Locked
Yes
HTTP response code
424
Failed Dependency
Yes
HTTP response code
425
Unordered Collection
Yes
HTTP response code
426
Upgrade Required
Yes
HTTP response code
428
Yes
HTTP response code
429
Too many requests
Yes
HTTP response code
431
Request Header fields too large
Yes
HTTP response code
440
Login Timeout
Yes
HTTP response code
444
No Response
Yes
HTTP response code
449
Retry with
Yes
HTTP response code
450
Blocked by Windows Parental Controls
Yes
HTTP response code
451
Unavailable for Legal Reasons
Yes
HTTP response code
456
Unspecified Error
Yes
HTTP response code
457
Unspecified Error
Yes
HTTP response code
494
Request Header too large
Yes
HTTP response code
495
Cert Error
Yes
HTTP response code
496
No Cert
Yes
HTTP response code
497
Http to Https
Yes
HTTP response code
498
Token Expired Invalid
Yes
HTTP response code
499
Client Closed Request
Yes
HTTP response code
500
Internal Server Error
Yes
HTTP response code
501
Not Implemented
Yes
HTTP response code
502
Bad Gateway
Yes
HTTP response code
503
Service Unavailable
Yes
HTTP response code
504
Gateway Timeout
Yes
HTTP response code
505
HTTP Version Not Supported
Yes
HTTP response code
506
Variant also Negotiates
Yes
HTTP response code
507
Insufficient Storage
Yes
HTTP response code
508
Loop detected
Yes
HTTP response code
509
Bandwidth limit exceeded
Yes
HTTP response code
510
Not extended
Yes
HTTP response code
511
Network authentication required
Yes
HTTP response code
520
Webserver is returning an unknown error
Yes
HTTP response code
521
Web Server is down
Yes
HTTP response code
522
Connection timed out
Yes
HTTP response code
524
A timeout occurred
Yes
HTTP response code
598
Network read timeout error
Yes
HTTP response code
599
Network connect timeout error
Yes
HTTP response code
1001
unsupported script version
Yes
Script error
from recorder and in responsecode.js → moved to errorlist Triggered when the script has no version or the version is neither 1.0 nor 2.0
1002
script syntax error
Yes
Script error
from recorder and in responsecode.js → moved to errorlist It's triggered when parsing the gslScript fails
1010
File downloads are currently not supported
Yes
Script error
The script has clicked on something that is trying to download a file. This is not allowed in Browser Monitors
1301
Hard / Transaction Timeout
Yes
Transaction Timeout
Transaction deadline of 5 min exceeded. Can be set via test configuration but not via the UI (transactionTimeout)
1302
Step Timeout
Yes
Step Timeout
Step deadline of 60s exceeded. Can be set via test configuration but not via the UI (stepTimeout)
1304
Wait for Page Complete Timeout / Time exceeded waiting for page to load completely
Yes
Step Timeout
Error code is thrown if the step deadline is exceeded while waiting for this
1305
Wait Network Timeout / Time exceeded waiting for background network activity to complete
Yes
Step Timeout
1306
Wait for validate Timeout
Yes
User Script Failure
1307
Wait timeout was too short for the page to load
Yes
Step Timeout
Error code is thrown when user defined wait timeout was too short for the page to load. This should be fixed within the test. (Increasing the wait timeout or change it to another wait condition; ea. "Wait for page to load completely")
1401
Validate Text Match Failed / One or more validations created for this action have failed
Yes
Content match failed
not generic error message any more, not used as it is but rather a detailed message of which element validation is failed
1501
Clickpath action failure
Yes
User Script Failure
This is also the default error in case we can't find the corresponding error type for an error. Usually, it means there's a bug somewhere in our code.
1502
Locator failure "The html element could not be found to perform action"
Yes
User Script Failure
A special case of 1501 Clickpath action failure where the failure was caused by missing or wrong locators so mainly locator failure. The player couldn't find the element to click on but if the validation before is not set to fail then it won't be a validation timeout error. 1501 will stay the default error in case we don't want to show the details of the error to the user (as it might be an internal error/exception)
1601
JS execution took too long
Yes
JS step errors
JS execution has a shorter limit than a normal step
1602
Exception was thrown
Yes
JS step errors
An exception occurred while the custom script was executing
1603
Test marked as failed by the user
Yes
JS step errors
The user itself marked the test as failed
1701
The specified target window is not found
Yes
Player error
The target window specified in the script was not found, either it was specified by mistake by the customer or the recorder record it wrongly.
1702
The specified target window got disconnected
Yes
Player error
The target window to event is using has been disconnected, usually this is where the window closes before the event has completed.
1801
Undefined placeholder was used
Yes
Script placeholders
Placeholder was used but was not defined
2001
playback window was closed
Yes
Recorder error
from recorder
2002
playback window was minimized
Yes
Recorder error
from recorder
2003
Extension is not enabled in incognito
Yes
Recorder error
from recorder (not defined in cluster), the text may change, behind a feature flag
2004
There is another incognito window open that needs to be closed first
Yes
Recorder error
10054
Connection Reset
Yes
Chrome net error
ERR_CONNECTION_RESET is caused by issues that prevent a stable connection between your browser and a website. The problem usually originates from misconfigurations in the visitor's device or network. However, temporary connectivity issues or firewall restrictions from a website's web server can also cause the error.
https://stackoverflow.com/questions/1434451/what-does-connection-reset-by-peer-mean
12000
Default network error
Yes
Chrome net error
This error is thrown when we get an unknown / new chrome network error which does not fit any other error. Since sprint 168 It will be here https://github.com/adobe/chromium/blob/master/net/base/net_error_list.h but not in our list.
12006
The site reported UNEXPECTED
Chrome net error
Chrome network error:net::ERR_UNEXPECTED error.
This is usually caused by an authentication issue. Try curling to the application from the ActiveGate, do you get a successful response? Often it is the case that a proxy is required to allow the ActiveGate to access the application. Or if you are already using a proxy, possibly you need to bypass it for the affected application. You can see the different scenarios available
here
Potential mitigation of this error is ignoring it using this experimental flag in Browser Monitor script:
   "configuration": {
      "experimentalProperties": [{
         "name": "IgnoreHttp2UnexpectedError",
         "value": "true"
12010
Failed
Chrome net error
Chrome network error net::ERR_FAILED
It sometimes shows up for CORS errors. If you playback the monitor locally, you can often get more information on the error from DevTools console.
12012
Address Unreachable
Yes
Chrome net error
12013
DNS Lookup Failure
Yes
Chrome net error
12014
Connection Timeout
Yes
Connection error Chrome net error
This error can be caused from 2 places, as an exception to cancel transaction when connectionTimeoutExceeded or as a chrome network error net::ERR_CONNECTION_TIMED_OUT. The first is when it takes so long to receive a response from the server. By default it's a 59 seconds unless specified otherwise in the script.
12015
Unsafe Port
Yes
Chrome net error
12016
Connection Refused
Yes
Chrome net error
12017
Too many redirects
Yes
Chrome net error
not in recorder This error is handled as netWorkError and it sets a connection error similar to 12014
12018
There is no Internet connection
Yes
Chrome net error
new in case of emulateNetworkConditions true and offline true
12019
Request was blocked by client / Malicious resource detected
Yes
Chrome net error but triggered by us
In case of coin mining url, we block the web request and report the error as it's reported by chrome.
12020
The site unexpectedly closed the connection
Yes
Chrome net error
Since sprint 142, in case a connection is closed from the server / proxy / firewall side.
12026
The site reported ERR_SPDY_INADEQUATE_TRANSPORT_SECURITY
Yes
Chrome net error
Since sprint 162
12027
The site reported ERR_EMPTY_RESPONSE
Yes
Chrome net error
Since sprint 167
12032
The site reported ERR_SSL_VERSION_INTERFERENCE
Yes
Chrome net error
Since sprint 168
12033
The site reported ERR_TIMED_OUT
Yes
Chrome net error
Since sprint 168
12034
The site reported ERR_BLOCKED_BY_CLIENT
Yes
Chrome net error
Something is preventing a webpage from loading certain resources. Check antivirus and firewall settings. Check troubleshooting steps in Firewall Constraints and allowlisting for Synthetic Monitoring
12035
The site reported ERR_SSL_PROTOCOL_ERROR
Yes
Chrome net error
For private locations, try disabling QUIC protocol, see Error code 12161. Check the AV settings. Check TLS versions used.
12047
The site reported ERR_TUNNEL_CONNECTION_FAILED
Yes
Chrome net error
For private locations, confirm proxy details are correct in custom.properties. See proxy scenario documentation
12049
The site reported ERR_SSL_CLIENT_AUTH_CERT_NEEDED
Yes
Chrome net error
How to avoid the Synthetic Browser monitor Error Code 12049 "ERR_SSL_CLIENT_AUTH_CERT_NEEDED"
12143
The site reported HTTP2_PROTOCOL_ERROR
Yes
Chrome net error
May be caused by firewalls like Akamai. In these cases, add Synthetic Browser Monitor traffic to the firewall allow list.
12161
The site reported QUIC_PROTOCOL_ERROR
Yes
Chrome net error
For private locations, you can disable QUIC protocol, by adding the following line to the user.properties file
com.ruxit.vuc.poolConfig.playerConfig.additionalStartupParams=--disable-quic
Linux:  Update /var/lib/dynatrace/synthetic/config/user.properties and then restart the vuc.service.
Windows: C:\ProgramData\dynatrace\synthetic\config\user.properties and then restart the Dynatrace Synthetic Gateway service.
12183
The site reported HTTP_RESPONSE_CODE_FAILURE
Yes
Chrome net error
This is a generic error which you need to check further into. It's alerting you to a status code that is not considered successful, usually 401, 404, 500 etc. Checking the screenshot is usually sufficient but if that does not reveal anything, you can check the waterfall and execution log (see Synthetic Player (VUP) logs section here)
20000
Unspecified Event Type Error
Yes
User Script Failure
Internal error when the event we want to simulate is unspecified. Should not happen.
20001
INVALID_USER_AGENT
Yes
User Script Failure
User Agent is Missing RuxitSynthetic part with test id and run id
20002
ABORT_PSR_ERROR
Yes
User Script Failure
Chrome startup error
What's Next
If this article didn't help resolve the issue, open a chat and provide
  • a link to the browser monitor that you are troubleshooting.
  • an explanation of the behavior you are seeing, and what you are expecting.
  • the troubleshooting steps you have already completed.
    You can find further troubleshooting tips for Synthetic in the Synthetic Troubleshooting Map
Version history
Last update:
‎23 Oct 2025 04:22 PM
Updated by:
Comments
AntonioSousa
@xu_guo,
Thanks a lot! I believe these codes should also be in the documentation.
BTW, do the 97? codes also appear in synthetics?
https://www.dynatrace.com/support/help/how-to-use-dynatrace/real-user-monitoring/setup-and-configura...
pathak_vivek
Observer
Hi @xu_guo
Do you have any idea how to get past and fix the error 12020 - The site unexpectedly closed the connection.
Ahmed_Khaled
Helper
There is also an error code 12006 Site Reported Unexpected, if anyone has experience with that.
HannahM
Dynatrace Guru
Dynatrace Guru
12006 Site Reported Unexpected is the Chrome ERR_UNEXPECTED error. This is usually caused by an authentication issue. If you curl to the application from the ActiveGate, do you get a successful response? Often it is the case that a proxy is required to allow the ActiveGate to access the application. Or if you are already using a proxy, possibly you need to bypass it for the affected application. You can see the different scenarios available here
Sravanth
Observer
We're observing "The request failed with error 12100: ABORTED"any idea what exactly this means? and possible causes?
Couldn't find any details in the docs.
Sravanth.
HannahM
Dynatrace Guru
Dynatrace Guru
"The request failed with error 12100: ABORTED" is seen where the request got aborted, and the browser doesn't provide any more details. Do you see the same in DevTools?
Sravanth
Observer
Hi @HannahM ,
No, we observe this error only in waterfall analysis of the synthetic executions and is intermittent with no real trend.
HannahM
Dynatrace Guru
Dynatrace Guru
OK, I would open a chat in the WebUI and provide a link to monitor and if possible a Har from when the page was loaded. Thanks
jordan_rose
Helper
Are these codes in the doc anywhere?
What does this one mean?
"healthStatusCode": 17,
"healthStatus": "CONSTRAINT_VIOLATED_VALUE",
HannahM
Dynatrace Guru
Dynatrace Guru
Is that from a Browser Monitor or HTTP Monitor? We mention it here for HTTP Monitors
Vaishnavi_Ubhe
Observer
@HannahM
Can you please tell me how to resolve the 403 error of the synthetic monitor?
The URL is getting loaded when I try in the browser, but somehow, it is throwing a 403 error in Dynatrace.
I have created RUM for this application, but no user actions are getting captured, to troubleshoot this I created the synthetic monitor which is throwing a 403 error.
Can you please help me with this?
AntonPineiro
Hi @Vaishnavi_Ubhe,
Is your synthetic running against public Dynatrace robot? Private location?
Best regards
Vaishnavi_Ubhe
Observer
@AntonPineiro
Is it running against a private location.
HannahM
Dynatrace Guru
Dynatrace Guru
403 is a forbidden error. Have you added credentials to the monitor to allow it access? If you open the page from the Private location does it have access? Sometimes customers need to explicitly allow certain machines to have access using a proxy or network rules.
alexandre_clava
Observer
I have the same behavior (intermittent as well).
Did you found the root cause and/or a fix ?
Best regards
Alexandre
Sravanth.
ScottD
Contributor
You're missing "1702 - The specified target window got disconnected".
AntonioSousa
I have observed today in a waterfall:
  • This request failed with error 12101: FAILED.
Haven't found any reference to it. What might it mean?
HannahM
Dynatrace Guru
Dynatrace Guru
"This request failed with error 12101: FAILED." is what the Browser monitor shows for resources when Chrome returns
net::ERR_FAILED
 Unfortunately, it's quite a generic error. It sometimes shows up for CORS errors. If you playback the monitor locally, you can often get more information on the error from DevTools console, assuming it's not intermittent.
CTull
Guide
l will add to the Horizon vmware application I am randomly getting this error.
12183 - The site reported HTTP_RESPONSE_CODE_FAILURE
HannahM
Dynatrace Guru
Dynatrace Guru
"12183 - The site reported HTTP_RESPONSE_CODE_FAILURE" is a generic error which you need to check further into. It's alerting you to a status code that is not considered successful, usually 401, 404, 500 etc. Checking the screenshot is usually sufficient but if that does not reveal anything, you can check the waterfall and execution log (see Synthetic Player (VUP) logs section here)
Quirina
Guide
Does anyone has experience with "NAME_NOT_RESOLVED" error? I have no idea the root cause of this error
HannahM
Dynatrace Guru
Dynatrace Guru
@Quirina "NAME_NOT_RESOLVED" means that the domain name you are using in the monitor cannot be resolved to an IP Address by the DNS resolver.
MightySandeep
Frequent Guest
I recieved the error 12033:
12033
Yes
Chrome net error
Since sprint 168
Does anyone of you got it before? And what to do about it?
HannahM
Dynatrace Guru
Dynatrace Guru
This means the request timed out. What happens if you try to curl to the endpoint from the Activegate? Try the troubleshooting here
