Upgrade to SaaS
All your question about how to move to Dynatrace SaaS answered in one place
Essential parts of Dynatrace for migration
Community Team
Community Team
Can you recommend what parts of Dynatrace are most essential to migrate to reduce the migration time to a minimum?
If you have any questions about the Community, you can contact me at maciej.neumann@dynatrace.com
Radoslaw_Szulgo
Inactive
As always - it depends. Based on the upgrade plan and target architecture in Dynatrace, execution of the upgrade moves all Dynatrace monitoring of workloads from the on-premises Dynatrace Managed environment to the Dynatrace platform:
  • The Dynatrace environments are created in one of the available regions.
  • All configuration is applied to the Dynatrace environment (either through automation or manually applying the necessary configuration to the SaaS environment).
  • Dynatrace components are moved (OneAgent) or replicated (ActiveGate) to the new Dynatrace environment.
  • Monitored applications are restarted to ensure that all monitoring is moved to the new Dynatrace environment.
To reduce the migration time to the minimum, leverage automation tools - such as Configuration-as-code and OneAgent automation capabilities - such as orchestration packages or oneagentctl.
The most common parts that are migrated:
Network Zones
User Groups  SSO Setup
Management Zones
Tagging Rules  Naming Rules
Custom Services  Services Configuration  Extensions
Synthetics  Cloud Automation  Process Group Detection
Application Definitions  Deep Monitoring Settings A Log Monitoring
Anomaly Detection  Alerting Profiles  Dashboards
Notifications & Integrations  Maintenance Windows  SLI/SLOs
API Tokens Credentials Vault  Mainframe Volumes
OpenTelemetry Cloud Platform Integrations Custom Metrics
Senior Product Manager,
Dynatrace Managed expert
