Hi Team,
Is it possible to monitor Paging File in windows server using DT one agent? Interest is , when Page File Name is "_Total" and alert when it's usage breaches threshold of 90%.
Many thanks,
Srikanth Samraj
You should be able to get the information that you want at the system level. In the host section, you should select memory and then "Swap usage":
If you want to setup alerts, you should use the metric: builtin:host.mem.swap.used
