parsing issue
sharmas2
Participant
I am looking for an ouput as below .
market Total albania czech ghana greece ireland itfixednw netherlands nlziggo portugal spain uk uklm voisind
Blocked 9001175 10836 56008 1416856 432310 1519 5290800 501189 45 11028 221512 1054954 3645 473
Detected 1474991 2158 1152029 19880 763 3282 35419 47660 971 1099 6314   205394 22
Below query is not giving the required output ..
fetch logs // scanLimitGBytes: , samplingRatio: 1000
| filter dt.system.bucket=="custom_group_security"
| filter contains(dt.security_context, "_sec_intel")
| filter contains(dt.security_context, "_sourcefire_secevents")
| filterOut contains(dt.security_context ,"ngss")
| filterOut contains(dt.security_context ,"gdc")
| filterOut contains(dt.security_context ,"sspp")
| parse content,"LD 'URLSICategory:' LD:URLSICategory ','"
| parse content,"LD 'URLSICategory :' LD:URLSICategory2 ','"
| parse content,"LD 'URLSICategory=' LD:URLSICategory3 ','"
| fieldsAdd URLSICategory = coalesce(URLSICategory, URLSICategory2)
| fieldsAdd URLSICategory = coalesce(URLSICategory, URLSICategory3)
| parse content, """LD 'DNSSICategory=' [^,]{1,100}?:DNSSICategory "," """
| parse content,"""LD 'InlineResultID":' LONG:InlineResultID "," """
| parse content, """LD 'IPReputationSICategory=' [^,]{1,100}?:IPReputationSICategory "," """
| parse content,"LD 'AccessControlRuleAction: '[0-9a-zA-Z-]{1,100}?:AccessControlRuleAction','"
| fieldsAdd Status = if( (InlineResultID == 5 OR InlineResultID == 0 OR InlineResultID == 2) ,"Detected",else:
if( (InlineResultID ==1 OR InlineResultID == 4 OR RuleAction == "Block" OR isnull(URLSICategory) OR isnull(DNSSICategory) AND isnotnull(IPReputationSICategory)), "Blocked", else:null))
| filter isnotnull(Status)
| summarize count(),by:{Status,market}
//| fieldsAdd market = substring(dt.security_context, to: indexOf(dt.security_context, "_"))
//| fieldsAdd market = replaceString(market, "cita", "")
//| fieldsAdd date = formatTimestamp(timestamp, format:"MM-dd-yyyy")
//| summarize co{market}, by:{date,Status}
//| fieldsSummary market ,Status
Please find the below raw data as well :-
May 08 2025 14:48:27 VCIMilanSecIntel : %FTD-1-430002: EventPriority=High, DeviceUUID=3fca3c60-fcae-11de-91ea-975343494af9, InstanceID=9, FirstPacketSecond=2025-05-08T14:48:27Z, ConnectionID=10078, AccessControlRuleAction=Block, AccessControlRuleReason=IP Block, SrcIP=83.222.191.170, DstIP=37.25.168.243, SrcPort=40227, DstPort=7356, Protocol=tcp, IngressInterface=DPB1-IN, EgressInterface=DPB1-OUT, IngressZone=CITADEL-Milan-DPB1, EgressZone=CITADEL-Milan-DPB1, ACPolicy=NGSS2-Milan, Prefilter Policy=NGSS2-Milan-Prefilter, InitiatorPackets=1, ResponderPackets=0, InitiatorBytes=58, ResponderBytes=0, SecIntMatchingIP=Source, IPReputationSICategory=Custom-Blocklist-Global-IP_FS, ClientAppDetector=AppID, HostName=IT1IPS03BIN1-1_2
{"EventType":"IntrusionEvent","EventSecond":1746715592,"EventMicrosecond":157111,"DeviceUUID":"3fca3c60-fcae-11de-91ea-975343494af9","InstanceID":18,"FirstPacketSecond":1746715591,"ConnectionID":37483,"InitiatorIP":"157.72.65.130","ResponderIP":"195.232.147.125","InitiatorPort":11768,"ResponderPort":123,"Protocol":"udp","IngressInterface":"DPB1-IN","EgressInterface":"DPB1-OUT","IngressZone":"CITADEL-Milan-DPB1","EgressZone":"CITADEL-Milan-DPB1","PriorityID":2,"GeneratorID":3,"SignatureID":39878,"SignatureRevision":4,"Impact":2,"IntrusionRuleMessage":"SERVER-OTHER Cisco IOS truncated NTP packet processing denial of service attempt","Classification":"Inappropriate content was detected","IntrusionPolicy":"Milan-Blocking-Policy_S3","FirewallPolicy":"NGSS2-Milan","FirewallRule":"To Legacy applications","NAP_Policy":"NGSS2-Milan-NAP-Snort3","InlineResult":"Block","VLAN_ID":3101,"Device":"IT1IPS03BIN1-1_2","DeviceIP":"198.19.40.21","DeviceSerialNumber":"FLM2443067L","EgressInterfaceUUID":"47a1da92-a6ac-11eb-b4ad-fb6eab37a80a","EgressZoneUUID":"47b3a240-a6ac-11eb-b4ad-fb6eab37a80a","EventID":1127183,"FirewallPolicyUUID":"00000000-0000-0000-0000-0000681c487b","FirewallRuleID":268436578,"Hostname":"IE1FMCATS1-A1","ImpactFlag":7,"IngressInterfaceUUID":"4759ef8e-a6ac-11eb-b4ad-fb6eab37a80a","IngressZoneUUID":"47b3a240-a6ac-11eb-b4ad-fb6eab37a80a","InitiatorContinent":"Asia","InitiatorContinentCode":"as","InitiatorCountry":"Japan","InitiatorCountryCode":"jpn","InitiatorCountryID":392,"InlineResultID":4,"IntrusionPolicyRevUUID":"82e629b0-6543-11ef-b36c-117b0c432ecb","IntrusionPolicyUUID":"a488735a-d4ea-0ed3-0000-326418261953","NAP_PolicyUUID":"cf0ab078-437d-11ef-ab6b-97ee0b432ecb","ProtocolID":17,"RealmID":0,"RealmName":"Invalid ID","ResponderContinent":"Europe","ResponderContinentCode":"eu","ResponderCountry":"Germany","ResponderCountryCode":"deu","ResponderCountryID":276,"SensorID":2,"SnortVersionID":3,"UserID":9999997}
5 REPLIES 5
Akhil-Jayendran
Advisor
Hello @sharmas2 ,
It looks like your raw data doesn’t contain all the expected fields, but the data appears to be in JSON format. I believe you can use a simple DQL query like the one below.
fetch logs
| filter matchesPhrase(dt.security_context,"_sec_intel") or matchesPhrase(dt.security_context,"_sourcefire_secevents")
| fieldsAdd Status = if( (inlineresultid == "5" OR inlineresultid == "0" OR inlineresultid == "2") ,"Detected",else:
if( (inlineresultid == "1" OR inlineresultid == "4" OR accesscontrolruleaction == "Block" OR isnull(URLSICategory) OR isnull(DNSSICategory) AND isnotnull(IPReputationSICategory)), "Blocked", else:null))
| fieldsRename market=respondercountry
| fieldsKeep Status, inlineresultid,accesscontrolruleaction,market
You might get result like this.
Br,
Akhil
Consultant | TEKsystems
no i want result as below ..
Hello @sharmas2 ,
In this case, you may need to modify the DQL to suit your requirements. Here’s an example
fetch logs
     else:if(
      else:null ))
| summarize by:{Status,market}, {count=count()}
| summarize {market_details= collectArray(array(toString(market),count ))},  by:{Status}
| fieldsAdd market_details=toString(market_details)
| parse market_details, "'[' KVP{ '[' DQS:key ', ' INT:value ']' ', '?}:market_details ']'"
You can see the data like this ? hope this will helps!
Br,
Akhil
Hi Akhil,
thanks for your efforts but  i am getting output as below ..
Hello @sharmas2 ,
You can try this ,  This is a sample query you should adjust this query according to your needs.
data json:"""[
{"EventType":"IntrusionEvent","EventSecond":1746715592,"EventMicrosecond":157111,"DeviceUUID":"3fca3c60-fcae-11de-91ea-975343494af9","InstanceID":18,"FirstPacketSecond":1746715591,"ConnectionID":37483,"InitiatorIP":"157.72.65.130","ResponderIP":"195.232.147.125","InitiatorPort":11768,"ResponderPort":123,"Protocol":"udp","IngressInterface":"DPB1-IN","EgressInterface":"DPB1-OUT","IngressZone":"CITADEL-Milan-DPB1","EgressZone":"CITADEL-Milan-DPB1","PriorityID":2,"GeneratorID":3,"SignatureID":39878,"SignatureRevision":4,"Impact":2,"IntrusionRuleMessage":"SERVER-OTHER Cisco IOS truncated NTP packet processing denial of service attempt","Classification":"Inappropriate content was detected","IntrusionPolicy":"Milan-Blocking-Policy_S3","FirewallPolicy":"NGSS2-Milan","FirewallRule":"To Legacy applications","NAP_Policy":"NGSS2-Milan-NAP-Snort3","InlineResult":"Block","VLAN_ID":3101,"Device":"IT1IPS03BIN1-1_2","DeviceIP":"198.19.40.21","DeviceSerialNumber":"FLM2443067L","EgressInterfaceUUID":"47a1da92-a6ac-11eb-b4ad-fb6eab37a80a","EgressZoneUUID":"47b3a240-a6ac-11eb-b4ad-fb6eab37a80a","EventID":1127183,"FirewallPolicyUUID":"00000000-0000-0000-0000-0000681c487b","FirewallRuleID":268436578,"Hostname":"IE1FMCATS1-A1","ImpactFlag":7,"IngressInterfaceUUID":"4759ef8e-a6ac-11eb-b4ad-fb6eab37a80a","IngressZoneUUID":"47b3a240-a6ac-11eb-b4ad-fb6eab37a80a","InitiatorContinent":"Asia","InitiatorContinentCode":"as","InitiatorCountry":"Japan","InitiatorCountryCode":"jpn","InitiatorCountryID":392,"InlineResultID":4,"IntrusionPolicyRevUUID":"82e629b0-6543-11ef-b36c-117b0c432ecb","IntrusionPolicyUUID":"a488735a-d4ea-0ed3-0000-326418261953","NAP_PolicyUUID":"cf0ab078-437d-11ef-ab6b-97ee0b432ecb","ProtocolID":17,"RealmID":0,"RealmName":"Invalid ID","ResponderContinent":"Europe","ResponderContinentCode":"eu","ResponderCountry":"Germany","ResponderCountryCode":"deu","ResponderCountryID":276,"SensorID":2,"SnortVersionID":3,"UserID":9999997,"dt.security_context": "_sec_intel"}
     (InlineResultID == "5" OR InlineResultID == "0" OR InlineResultID == "2") ,"Detected",
     else:if(
     ((InlineResultID == "1" OR InlineResultID == "4" OR accesscontrolruleaction == "Block" OR isnull(URLSICategory) OR isnull(DNSSICategory))), "Blocked",
      else:null ))
| fieldsRename market=ResponderCountry
