We run on a managed cluster and recently upgraded to 1.202, which includes the Data Explorer tile.
We use the old timeseries v1 api to ingest custom metrics and display them in realtime on a dashboard. When trying to replicate the functionality of displaying timerseries data we have already existing on these dashboards with the new Data Explorer and metrics v2, we run in to a couple of issues, can anyone advise if I'm doing it wrong, or address if these are known issues and will be resolved in a future release?
List of issues:
This is great feedback, I know Dynatrace is working on some improvements but I'm not sure what the time is for the updates to it. I thought there was a feedback channel for this, but I cannot find it any more
The data explorer (upcoming replacement of custom chart) made huge progress from the 1.202 (first publicly available version). Many of the issues you describe have been already addressed in recent versions (1.207/1.206). Just upgrade you managed cluster to version available ( you can't skip the upgrades anyway ).
Hello @Chad T..
We found additional bug .
when we use a widget Data Explorer on a dashboard, and then we share this dashboard with a user without authorization, then the user does not have data for this widget.
We use 1.206.119.20201208-162938
1. my dashboard
2. Shared dashboard
