Snowflake monitoring through Dynatrace
Chandnipatel
Participant
Since Dynatrace can monitor Snowflake, apart from the metrics listed in the document (https://www.dynatrace.com/hub/detail/snowflake/) can Dynatrace also help to monitor the below use case?
Use case: The client is using Snowflake for store procedure execution in the Database. the pain point is that some store procedures are executed multiple times despite scheduling it only once, leading to duplicate SP executions and DB records submission. Can it be tracked by Dynatrace monitoring?
For example : If the same store procedure is getting executed for more than once in a targeted timeframe?
Chandni
0 REPLIES 0
