Open Q&A
Dynatrace SaaS - DAVIS integration with Slack: Problem comments
matthew_eisengr
Inactive
In the WebUI for SaaS -> Problems, you have the ability to add a comment to the problem.
If you have DAVIS integrated with Slack, could you use that as a method to comment on a problem directly from Slack?
3 REPLIES 3
matthew_eisengr
Inactive
...or is there any other way to comment on problems besides through the WebUI?
Ok, I see you can do it through the WebAPI here: https://www.dynatrace.com/support/help/dynatrace-api/problems/how-do-i-push-or-add-comments-to-problems/
pahofmann
Yes you can add comments via DAVIS, there are many ways!
You can do it via the alexa skill, the DAVIS chat interface or integrations like Slack.
Here an example from the DAVIS chat UI:
