Open Q&A
Please Clarify: Self-Monitoring Metrics for Adaptive Capture Control - SaaS
r_weber
DynaMight Champion
DynaMight Champion
@markus_pfleger (nice virtually meeting again after such a long time)
@christoph_hoyer
I was looking at the new Self Monitoring Dashboards based on what can be found in the Hub and what is presented in this webinar and in the documentation.
There seems to be conflicting information on how the capture rate is defined and even in the video it's done in different ways at two points I think.
First there is the "OneAgent Capture Rate" as explained in the documentation:
The oneagent capture rate seems strange, as in my case the number for oneagent.service_calls.processed is much higher that the server.service_calls.received (see below). The resulting rate is therefore really low. Whereas the serverside Capture Rate is 100%.
The Server Side "Capture Rate" is calculated like this:
This one seems logical, server receives calls and persists them. If equal we are all good.
Since for SaaS there is also the server.service_calls.maximum_allowed_per_minute, does this mean for SaaS - assuming that the "processed" service calls will always be limited before to match the "persisted" so that the capture rate is always 100%?
What if the "received" calls exceed the "service_calls.maximum_allowed_per_minute"?
Would you consider this environment healthy? (I'm observing data loss and strange metric behavior on services)? I have added these metric calculations:
"Persisting Rate" = (dsfm:server.service_calls.persisted)/(dsfm:server.service_calls.received)*(100)
"Capture Rate" = (dsfm:server.service_calls.received)/(dsfm:oneagent.service_calls.processed)*(100)
"Percentage of Capture Limit" = (dsfm:server.service_calls.received:splitBy():avg:auto:rate(1m)/dsfm:server.service_calls.maximum_allowed_per_minute:splitBy():avg:auto)*100
For SaaS I'm interpreting this as:
As the "oneagent.processed" (yellow) service calls is much higher than the "server.received" something is dropped somewhere, not considered at all, or the "oneagent.processed" metric includes calls that are not relevant?
Note that the Persiting Rate is constant 100% although the Capture Rate fluctuates depending on the load. Hence my assumption something gets dropped before the received metric is calculated (server side drop, rate limit).
And then there is the  "server.service_calls.maximum_allowed_per_minute" which I understand should be compared to the "server.service_calls.received" metric to understand if (in SaaS) you produce more service calls than your limit allows. The "Percentage of Capture Limit" metric calculation in my case would tell me that I'm 330% over my limit - which would explain the "data-loss" or heavy aggregation I'm seeing on individual services.
Can you confirm this or am I missing something?
6 REPLIES 6
ChadTurner
DynaMight Legend
DynaMight Legend
@r_weber were you able to get any clarity on this?
-Chad
fstekelenburg
DynaMight Pro
DynaMight Pro
I come here because I have the same question regarding Dynatrace Managed.
To me it is also unclear where the "server.service_calls.maximum_allowed_per_minute" is configured. If I have a current max of 5.4k, where  does that come from?
Kind regards, Frans Stekelenburg                 Certified Dynatrace Associate | Cegeka.com, Dynatrace Partner
This metric is not appliable to Managed, we need it for ATMv2 in SaaS and is not used in Managed.
Thanks for the confirmation and explanation.
"server.service_calls.maximum_allowed_per_minute" algorithm is 250 per HostUnit connected to the environment (HostUnits * 250), with a minimum of 5000.
If not applicable to Managed (and not limiting traffic), it is at least a metric that can be used in case migration to SaaS is considered. 🙂
Andreas_Gruber
Dynatrace Enthusiast
Recently our documentation got updated, I think it is a good read which should cover your questions. https://www.dynatrace.com/support/help/observe-and-explore/purepath-distributed-traces/adaptive-traf...
Nevertheless I also want to summarize:
This metric represents all service calls OneAgent processes before any sampling (Adaptive Traffic Management) is applied. Based on the customers license we may not send all the data to the cluster. This means we sample data and OneAgent does not send all tracing data to the cluster. The data we send to the cluster contains information about sampling to be able to extrapolate the data the on the cluster.
Now the processing on the cluster takes place. In some overload situations we keep the cluster healthy by sampling data (Adaptive Load Reduction). If this happens we process less data then we receive and the received metric is higher then the processing metric.
dsfm:server.service_calls.processed
After processing the data, the data gets persisted. Processing and persisting are separated therefore it could also happen in certain overload scenarios that the processed and persisted metric are not equal. Also they are written at different points in time so they have not the exact values but the sum over time is typically the same.
In the end we have the limit metric, representing the limit the customer is allowed to send based on the license. So if the customer sends too much, OneAgent lowers the sample rate, resulting in sending less data. Then we receive only the amount of service calls the customer is allowed to send.
Thank you @Andreas_Gruber, this is very informative. The documentation is a good starting point but it lacks somewhat this kind of detail.
Now I am interested in more detailed explanation about how the sampling if effected (Adaptive Traffic Management and Adaptive Load Reduction). What is the rate, what determines/limits the rate, and what can be done to (positively) influence the rate (with examples), e.g. what is the effect of adding a node, or raising a threshold. To aid customers in capacity planning and application impact analysis. But that is another topic, article, I guess. Or is there already an article somewhere that I overlooked?
