15 Dec 2020 04:37 AM
I understand the thinning out of purepath with "Adaptive traffic management and control".
But I do not understand that this thinning out has the Priorities of thinning?
So, are slow or error puthpaths saved preferentially on Dynatrace cluster?
Best regards,
Yasuo Ohnishi
15 Dec 2020 11:40 AM
New PurePaths coming in from environments with the highest traffic in relation to their assigned host units (i.e., traffic/host unit) are targeted first for load reduction. Dynatrace Managed skips full PurePath processing in these environments. This happens in a random fashion and reduces the number of PurePaths that are processed in a staged fashion. At the same time, the statistical validity of all metrics, charts, baselining, and events is retained because Dynatrace knows the number of PurePaths that have been skipped. This is fully transparent to you, as Dynatrace raises an event and displays a message in the cluster UI.
Hope this helps.
15 Dec 2020 02:03 PM
@Radoslaw S. can you share if the load reduction on the OneAgent takes request naming rules into consideration?
Let's consider this example:
Will OneAgent reduce the number of processed PurePaths based on final request name? (after naming rules are applied).
