28 Nov 2022 01:50 PM - last edited on 28 Nov 2022 02:07 PM by Karolina_Linda
Hello. Can anybody tell me - max length of x-dynatrace header. Customer setting up firewall rules, so they need max length all request headers to allow application work, otherwise requests are blocked.
Thanks.
Alex
28 Nov 2022 01:59 PM
I don't believe there is a size limit from a Dynatrace perspective. Typically, the HTTP header size limit is dependent on the server. (Apache, Nginx, IIS, Tomcat)
28 Nov 2022 02:19 PM
I need value from Dynatrace. Expected answer - for example 200 symbols.
Look like this:
FW4;-712055999;35;-1057699572;862004;0;1310537445;1367;c15c;2h01;3hc0f4c90c;4h0d2734;6h6765016c4c42ea4085044906606ef4e6;7hc487f83ef5f244e3
This header added by Dynatrace. Only Dynatrace can know it. The question is not about web server settings.
Alex
29 Nov 2022 06:46 AM
Unfortunately the header length is not fixed. Depending on the situation encoded binary info will be added to header.
Harry
30 Nov 2022 09:58 AM
Thanks for fast response.
